Assembly: Precise part placement
tj_thorniley
Member Posts: 65 ✭
Below are some neodymium magnets, placed on a plastic part. They've been placed freehand (XYZ Transform, No Mates), but I'd like them to be precise.
Is there a way to do that?
Would be nice if I could use the existing lines, and place them an equal distance from the surrounding edges and/or fillets, etc.
FYI: In reality, they will simply be fixed with some kind of glue/adhesive. Thanks.
bruce_williams
Member, Developers Posts: 842 EDU
@tj_thorniley
a cool trick for centering is to make some construction geometry on a sketch. In your example 3 construction lines connecting the edges to center; then add an equal constraint to the three lines. You may either use this method to make a 'layout sketch' or add an explicit mate to use in assembly. See screen shot below and document here (also note sketch one is a screenshot I used to trace over, so ignore my sizing since I have no idea actual) -
https://cad.onshape.com/documents/5f0f01f208648552e325bcd0/w/3da86721ea762e8bfb292d4b/e/24ac2c2ed0987117c8cdfb4d
www.accuratepattern.com5
In a previous thread for @tj_thorniley I've already built him a document with an example of how to transform things precisely with mate connectors.
Assemblies are even easier to mate and the help files and tutorials are excellent.
@tj_thorniley As ever it's hard to help without a link to the document, and at least meet us half way and read the help then post with the problem you're facing. Your "is there a way to do that?" question indicates you've not put much effort into reading the help files, doing the tutorials or even just pressing the buttons to see what they do.
Sorry if that sounds harsh, but come on fella.
As @owen_sparks said, if you copy and paste the link to your Document here we can take a look and assist further.
Twitter: @bradleysauln
