Loft difficulties
Chris_S_2018
Member Posts: 3 PRO
I am trying to do some what I believe should be simple lofting between a circle and an ellipse. When I try to apply a guide or path constraint sometimes I can get them to work and sometimes I can not. I keep getting the "loft path must pass through all profiles or their paths." error. I have tried to make sure all my points are coincident between the planes and guide curves/paths.
For the guides/paths I want to use a spline, but to simplify things I have switched to a straight line.
I have been through many tutorials online. None of the tutorials appear to explain the differences between guides and paths.
I need to know not what is just wrong with this error, but more importantly how I can use guides consistently.
Hello Chris! Can you share your example as public and paste the url into the forum? Thank you in advance!
Twitter: @bradleysauln
https://cad.onshape.com/documents/d6947a8c6e1a6ae034cec202/w/dd91caac1c5cecba868037f1/e/6b3e91ddecb7c1c1ddc2f758
I'm still seeing some weirdness.
***Edit, please note that the numpty that wrote this didn't read the instructions properly
(a) Doing as Neil suggests and then selecting the whole "sketch4" from the feature tree as the guide works fine.
(b) As above but selecting the individual sketch4 entities in the graphics area fails to loft
(c) Selecting the same entities to make a composite curve and then using the new curve as the guide works fine also.
Linky
Confused.com
Owen S
You selected each curve segment as a new guide curve. Instead click the > at guide to expand it and then select all segments into one guide. Now that is (my favorite word...wait for it....) ESOTERIC.
Thanks for hammering on that Owen; now I learned even more!
@bruce_williams, at least one of us is prepared to RTFM.
Now you mention it I remember thinking "that's clever" when OS released it. Doh.
"To select tangentially connected curves as a single guide, click the down arrow next to the selected guide to open the field for more selections. Make additional selections:" In my pedantic defence it only turns into a down arrow after you've clicked it, before then its an across arrow
Ooops. Then again if I'm dull enough to get it wrong presumably others will too. OS is there an opportunity to make this a bit more obvious from an UX point of view, some sort of anti-numpty methodology?
I'm going to give up thinking until the new year, I've clearly lost all aptitude for it.
Cheers all,
Owen S
In any case, I just learned more about how to properly do lofts in this conversation than I understood from the ~10 videos, the manual, and various other loft-related posts that I have looked at for the last two days. Appreciate the walk-thru and easy to follow explanations and the picture that shows how to select the individual components to make a guideline.
This is a pretty friendly forum to bounce ideas around in so feel free to keep asking questions.
If you've got an Extrude question I might even be able to answer it correctly.
Cheers Owen S.
You did well with that question!
Owen S
This seems obvious to some I'm sure, but it took me a while to realize the word "intersect" was being used in those how-to-loft videos for a reason
