Spline handles Randomly non-existant
David_LaPoint
Member Posts: 10 ✭
Here I drew a closed spline, none of the points have handles to control angles off the points. Why does this happen to me now?
john_mcclary
Member, Developers Posts: 3,980 PRO
OnShape Splines only add control handles to the start and end points. If you close the spline then you lose the start/end points. I'm not sure why it is this way, but I've found adding or removing points and I can get the shape needed.
I'd like to see what @matthew_chapman has to say on this
5 -
matthew_chapman
Member, Developers Posts: 4 ✭✭
Thanks for the 'A2A' @john_mcclary
Handles only apply at end points where the spline is 'open'. At other points, the spline is calculated such that it passes smoothly through the points, such that a single smooth curve is created (with 1st and 2nd derivative continuity).
Given the fitting scheme that Onshape uses, a given set of points will always result in a particular curve. If the curve is not to your liking, you need to add or remove points as John suggests. Often the physical constraints of a CAD problem will dictate the points that a curve must pass through.
Hope this helps,
Matt8
Hope this helps,
Matt
