Jump to feature script functions from inside feature script.
Chad_Fortune
Member Posts: 6 PRO
When going through code in many different feature script files, sometimes you need to go into a custom script definitions to see how it is being used. This becomes difficult not only when there are many different script (files?) in the same document, but also when the script is inside an imported document. Being able through a context menu to jump between code would avoid having to find which file/document the functions are written in.
Example from VS:
Example from VS:
I learned of the CTRL/CMD after sending the request. It only seems work as long they are in different documents. The fractInches() function is in an imported FS and the CTRL/CMD works on it, but not the new function.
I just noticed while creating this that newFunction doesn't show in autocomplete while imported function does.
