@opBoolean: BOOLEAN_SAME_INPUT error message
I am trying to create 2 holes in the same body using an adaption of the featurescript from "Dowel and Minifix", I can create and subtract the first hole and create the cylinder for the second hole but when I try to subtract that I get the error "@opBoolean: BOOLEAN_SAME_INPUT".
My code is as follows:
<div> // Create Hole cylinder geometry </div><div> fCylinder(context, id + THstr, { "bottomCenter" : THBot1, "topCenter" : THTop1, "radius" : TH_RADIUS });</div><div> </div><div> // Subtract Hole Geometry from all other bodies to create holes. </div><div> opBoolean(context, id + THbooleanstr, { tools : qCreatedBy(id + THstr, EntityType.BODY), targets : everythingelse, operationType : BooleanOperationType.SUBTRACTION });</div><div> //Update ID Strings </div><div> THstr ~= 1; </div><div> THbooleanstr ~= 1;</div><div> </div><div> // Create 2nd Hole cylinder geometry </div><div> fCylinder(context, id + THstr, { "bottomCenter" : THBot2, "topCenter" : THTop2, "radius" : TH_RADIUS });</div><div> </div><div> //Works fine up to this point </div><div> // Subtract Hole Geometry from all other bodies to create holes. </div><div> opBoolean(context, id + THbooleanstr, { tools : qCreatedBy(id + THstr, EntityType.BODY), targets : everythingelse, operationType : BooleanOperationType.SUBTRACTION });</div>
I have tried googling the error but no results.
If there is a way to subtract multiple bodies that would be even more useful!
Thanks in advance for any help.
NeilCooke Moderator, Onshape Employees Posts: 5,886
Without testing I don’t know what is causing the error, but you can use qUnion for the tools argument and subtract both in one operation.Senior Director, Technical Services, EMEA5
"everythingelse" is created by subtracting a created hole cylinder from literally everything else so I had to update that to be the new hole cylinder I had just created and it worked fine.
added...
as follows:
Your qUnion suggestion is a good one so will try that.
EDIT: correction - your code is fine since your first statement is just constructing the query not executing it (which is done in opBoolean). Sorry!
