Aligning and creating aligned holes across part studios?
Opening a topic just because there perhaps is an easier way I don't know about...
I'm designing a frame on which blocks need to be mounted and held into place by a strip and a separator.
The separator will be welded onto the beams after having the parts laser cut.
The top mounting strip will be bolted on.
Therefore I need holes in the beam, separator and strip that align with each other and the mounting flanges of the blocks.
1. Beam = light blue
2. Block and mounting fin = green
3a. Separator = grey
3b. Top strip not shown
Part 1, 2 and 3 are all in separate Part studios and the above screenshot is from the assembly.
My current approach is:
- Copy pattern of mounting flange as sketch entities
- Paste and use them in the separator part studio to create the separator
- Put those together in an assembly
- Measure in the assembly where the holes need to be in the beam
- Copy the pattern of the separator edge to a sketch in my beam/frame part studio and use the extrude/remove functionality to create the holes.
In the end I do achieve the results I want, but somehow I am under the impression that there should be an easier way to use/align parts across part studios. Is that indeed the case? Hope you can help me out in improving my CAD and Onshape skills.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,432
    Have you tried modelling them all in the same part studio? If that’s not possible please see https://www.onshape.com/cad-blog/onshape-just-took-the-lead-on-top-down-design
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    edited January 2018
    @lars_rengersen
    I think you should have modelled your parts in the same part studio.
    It would then be much easier to do what you are asking.
    Check out this link to learn how to do multi-part part studios:
    https://learn.onshape.com/courses/fundamentals-multi-part-part-studios
    You could also edit in-context:
    https://cad.onshape.com/help/#in-context.htm
    lars_rengersenlars_rengersen Member Posts: 32 PRO
    Wow guys, thanks!
    Glad I asked my question here, your answers help me a lot.
    From the blogpost and video "ONSHAPE JUST TOOK THE LEAD ON TOP-DOWN DESIGN" I learned about the "Edit in context" which is very helpful to continue working with my current design and approach.
    From the course "Fundamentals 4: Multi-Part Part Studios" I learned how to balance between designing parts in the same part studio or not.
    And Derived was also new to me and is also very helpful in my case since due to the nature of my design and project I can't put everything in one part studio.
    For example the blocks shown will be used in two separate boxes, as well as the separators and top strips.
    Only the frames and number of blocks are different.
