Dimensions to min, max, or center of diameter
in Drawings
I'm sure there is a way to dimension to the outside or inside edge of a diameter or radius (min / max)? I attached a drawing below the is an example of what i mean. Top view dimension is pulled from bottom to outside, lower view is pulled from bottom to center of the radius. In solidworks, you can send the leader arc condition to min / max with a check box. Is there a way to choose which option i want?
