opExtractSurface using derived feature
papawo
Member, Developers Posts: 206 PRO
but i must say qEdgeTopology should be qEdgeTopologyFilter
Add a function at the bottom named qOuterSketchRegions:
</code>export function qOuterSketchRegions(features is FeatureList) returns Query { var query = []; return qUnion(query); for (var feature in features) { query = append(query, qSketchRegion(feature.key, true)); // true to filter out inner loops } } </pre><div>(This function uses the standard <span><a href="https://cad.onshape.com/FsDoc/library.html#qSketchRegion-Id-boolean">qSketchRegion</a> function, which has a filterInnerLoops option)</span><br><br>Then change your definition of profileEntities to:<br><pre class="CodeBlock"><code> const profileEntities = qOuterSketchRegions(definition.profile);Example document:
https://cad.onshape.com/documents/14f1f8d4f2979c9f4e6ffacc/w/1e643421e968f502e2ecf590/e/32fceec70cdf2150e1c75386
