Rotating the view with right mouse button always triggers a popup in chrome
adrian_maleska
Member Posts: 6 ✭
This is a very strange thing - however I try just to rotate in the view using the right mouse button (just rmb or alt+rmb) a popup appears - which is rather annoying ;( Does someone know what's the problem might be and how to solve it? I'm using Windows 10 and the chrome browser.
Is this a new issue? Have you changed browsers or computers recently? Just to be sure, you have to hold down the RMB while you are trying to rotate.
From day 1 have changed it to be MMB as it is what I'm used to in other places.
You can change that in your account settings
UPDATE
Fortunately my navigation problems seemed have vanished somehow. I'm not sure if the Onshape team made an fix or something else solved this bug. But I'm happy that I can work now properly without annoying popups.
