Pattern not updating
I made a change to some of the dimensions of my part and the circular pattern for sketch #5 did not update to reflect the change. It's really weird because the system didn't throw any errors.
https://cad.onshape.com/documents/9263dbe7a1843f5c4410b61b/w/9f8d0dc13f28aed4ad2bf84f/e/c4df1e78ad8b7691e9cddf82
  • callum_keddiecallum_keddie Member Posts: 2 EDU
    Nvm, I found a workaround
    Currently if your pattern is a feature pattern, sketches with external constraint references are not picked up. We are working on supporting this in the future. You probably found a work around using the part or face pattern options.
