What determines whether custom features can be copied from another document?
edward_petrillo
Member Posts: 100 EDU
When I attempt to copy a custom feature that I added to another versioned document that I own, the document appears grayed out in the "add custom features" dialog window and clicking on it returns the message "no custom features available" . The destination document has been versioned. What must I do to make this operation possible?
NeilCooke
Moderator, Onshape Employees Posts: 5,927
When you say “added” do you mean you wrote it? If so, make sure that the version was made after the feature was complete. If you did not write it, but simply used it in the first doc then you must find the original to add it to your toolbar.
If I’m way off the mark please post back and we’ll try to find out what’s wrong.
Senior Director, Technical Services, EMEA5
I'm trying to make it as easy as possible for students to access a preferred set of features without having to browse for them.
Be cautious with this workflow. If you copy the document to get at its custom features, you will have no way of knowing if the original writer updates their feature to a new version. If you add the feature directly from the original document, there will be a notification and upgrade option for any code changes.
A suggestion: Create a google doc containing links to all the original custom feature documents.
Although, there is the upside that copying all these documents ensures that your students are all running exactly the same code, so maybe this is a good workflow for you!
Was the version created before you inserted the custom feature into your document?
If it was, try creating another version on top of that
