What determines whether custom features can be copied from another document?
edward_petrilloedward_petrillo Member Posts: 84 EDU
When I attempt to copy a custom feature that I added to another versioned document that I own, the document appears grayed out in the "add custom features" dialog window and clicking on it returns the message "no custom features available" . The destination document has been versioned. What must I do to make this operation possible?
  • edward_petrilloedward_petrillo Member Posts: 84 EDU
    Got it- that's what I suspected.  So if I make a copy of someone else's feature, I own the copy and can share it with my team.
    I'm trying to make it as easy as possible for students to access a preferred set of features without having to browse for them.
    @edward_petrillo
    Be cautious with this workflow.  If you copy the document to get at its custom features, you will have no way of knowing if the original writer updates their feature to a new version.  If you add the feature directly from the original document, there will be a notification and upgrade option for any code changes.
    A suggestion: Create a google doc containing links to all the original custom feature documents.
    Although, there is the upside that copying all these documents ensures that your students are all running exactly the same code, so maybe this is a good workflow for you!
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
    @edward_petrillo
    Was the version created before you inserted the custom feature into your document?
    If it was, try creating another version on top of that
    Thank you @Jake_Rosenfeld for the warning and Google Docs suggestion- we'll work something out.
