Curved line to sheet material?
I designed a simple curved shape that I want to saw from a sheet of MDF. How can I get the dimensions of the curved shape so that I can draw it manually onto the MDF and saw it out with my jigsaw?
    Jan - you could print the drawing (or just a dxf/dwg) at 1:1 scale and attach that to the MDF. Just follow the lines with your jigsaw.
    Philip Thomas - Onshape
    Or if the sheet is too large add a bunch of points to your sketch along the curve, use the dimension tool to get x/y coordinates, transfer those to the MDF and finally join the dots by hand.
    For an approximate transfer you can use a projector and trace the image while projected to sheet.
    www.accuratepattern.com
