Selecting solid lines rather than lines lines by default when the 2 are on top of eachother
I have a complicated pattern that I am trying to sketch out, and I have a few construction lines to make things easier, but whenever I need to select a solid line that is on top of a construction line I have to use <RightClick> ==> <Select Other> to select it.This is REALLY annoying. How do you tell Onshape to prefer to select the solid lines?
