Insert current view in drwing mode
Fredrik_HögströmFredrik_Högström Member Posts: 5 PRO
edited January 2018 in Community Support
There is a function in inventor and solidworks that is insert current view. I miss that one :)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    @Fredrik_Högström you can create a Named View in the model (from the view menu under the view cube) and insert that view into a Drawing. Is that what you are looking for?
  • Fredrik_HögströmFredrik_Högström Member Posts: 5 PRO
    Perfect. thanks
