Surface-to-surface add bug?
Member Posts: 63 PRO
Hello. I'm trying to make a sheet metal part in 3 dimensions from surfaces. In doing so, I am trying to use the "fill" command, because it has the ability to be done as "new" or "add". Yesterday, I got the error message that these two surfaces did not share an edge (even though they do), and today Onshape doesn't give me a message, it just creates a new (purple) surface despite designating the adjacent yellow surface to the "merge with".
In other words, it just "forgets" the merge choice and creates a new surface. The feature is greyed out in the feature tree.
  • Member Posts: 25 ✭✭✭
    We need to be able to knit and trim surfaces together.
  • Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    edited May 2018
    @dan_engerer
    @Mark_Matthews
    @lougallo
    Use offset face with an offset of 0, then try this feature: https://cad.onshape.com/documents/84d939daceef6a928b8abcba
