U channel into concave side walls
mark_cunningham
Member Posts: 78 ✭✭
in Drawings
I have a part that needs the "U" shaped channels to be concave at left and right sides. Can this be done or should it be a hole and trim the tops?!
Welcome to the forum! You will find lots of helpful people here including top guns from OS.
Not sure what you are after without a shared document or at least screenshot or sketch. You can make your document public and share a link here and you will get help quickly. See the link icon above.
You should be able to extrude any region. I have attached this example document. Just show us what you are after and we can help.
We do not see your link.
Two steps to share on the forum 1) make the document public 2) copy & paste the document link into the comment using the 'Url' icon. (see picture below) btw you can highlight text before hitting the Url icon and that will become a link like I have above with the text 'example document'
https://cad.onshape.com/documents/21168b37c079345ad2b5a562/w/c53456083c9820d5b7d23bb2/e/7adff33abd5d4d7410e7ac9a
