I'm having trouble with skPolyline --- ALREADY ANSWERED...
ron_moreland
Member Posts: 90 ✭✭✭
I am having trouble with this code:
Can you see the problem? I suspect I need to declare a vector array, but I don't know how to do that.
var fPoints is array = [];
var L = 10.0;
var CL = L;
var Rule = 1.0 ;
for (var i = 0; i < definition.numberOfF; i += 1)
fPoints = append(fPoints,vector(0,CL*inch));
CL = CL/Rule;
skPolyline(sketch1, "polyline1", {
"points" : fPoints
});I'm getting "Precondition of skPolyline failed (is2dPointVector(value.points))" in the error window.Can you see the problem? I suspect I need to declare a vector array, but I don't know how to do that.
