Issu with opSplitPart
MikeSarrey
Member Posts: 2 ✭
Hello all !
I'm a new Onshape user and I'm trying to make my first script.
This script goal is to make a helical cam like this :
I made this part using Solidworks pretty easily using 3d parametric curve but it seems that there are no similar feature on Onshape. That's why I'm trying to write it by myself. Actually, I almost succeeded by genereting with the script the 2 curves, creating a surface between them and a ring. My problem is with the opSlipPart. I don't understand how it work. I want to split the ring with my wave surface and to keep the part from
https://cad.onshape.com/documents/6d44ab7129cbaa1042d4ab5a/w/a7f47da4d52d7aa4e1c1f1e5/e/14c0ced3d21998160c14140b
https://cad.onshape.com/documents/fe622d67f34560a1c1e2a0ca/w/7a13fae6edb7aed2a88c4cf1/e/13d6aedaac72d5c14499c2a7
