Reorient Part to A Different View
terry_pike
Member Posts: 14 ✭
If I create a part which shows the top view, can I redefine that view and say it's the front view. In Inventor, this was no problem, but I can't find an option for this feature. Thank you!
Optionsbruce_williams Member, Developers Posts: 842 PROHere is discussion thread on 'Reset view'. There are work-arounds but not directly possible yet.
I thought there is an improvement request and I could not find it.www.accuratepattern.com5 -
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646@terry_pike
You can use the Transform feature to rotate the part (rather than changing the views themselves):
https://cad.onshape.com/help/Content/transform.htm
'Rotate' or 'Transform by mate connectors' options are your friend here.
Jake Rosenfeld - Modeling Team5 -
Optionsterry_pike Member Posts: 14 ✭bruce_williams said:Here is discussion thread on 'Reset view'. There are work-arounds but not directly possible yet.
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@terry_pike - In addition - if your question is driven by the need to create drawings, dont forget that you can define a named view that can be referenced in the drawing view.Philip Thomas - Onshape5
