Exporting assemblies as multiple .stl and retaining assembly origin
pete_kpete_k Member Posts: 3 ✭✭
Drawing ref:
https://cad.onshape.com/documents/f312b2b905821d889338dd60/w/203be7d7a7a8aaa74b6d2cd1/e/430524f182b277f30ef72c3c
Hi,
I've been trying to export a model for 3d printing, it consists of two parts for dual density extruding. In order to line up the model in the slicer software (Simplify3D) I need to export the assembly of the two parts with a common origin so that Simplify3d can place it correctly in the modelspace (Simplify3D's transfrom tools are very basic, so it needs to drop in perfectly, first go ideally).
When I export the assembly in OS and use 'export unique parts as individual files' option the parts are exported with an origin that looks something like the geometric centre of the part (or the original part origin?), and not the origin defined in the assembly - so no good for multi extruder 3d printing.
Assembly in OS with origin:
Part imported into Simplify 3d - origins all wonky.
When I export the assembly with the 'export unique parts as individual files' unchecked, the part renders in Simplify3D with the correct origin. Which is weird, but still not good for 3d printing as i need two distinct parts!
Part exported as one .stl - origin is correct to the assembly in OS.
What am I doing wrong here? I assume there is an option to export using the assembly origin or something that I haven't found for the multiple part export... Done a lot of trawling forums and tutorials this evening but none the wiser.
I can replicate the problem with my old slicing software RepG - so i think the .stls are coming out of the export process with the missing origin data somehow.
thanks
Pete
    Hi, I'm fairly sure that if you don't check this "export unique parts as individual files" then you'll be fine.
    Cheers,
  • brooks_talleybrooks_talley Member Posts: 27
    Owen is correct... this is my workflow for OnShape -> S3D:
    1. Design parts in OnShape
    2. Select multiple parts
    3. Right click and choose Export...
    4. Uncheck "export unique parts as unique files"
    5. Download zip file
    6. Extract all files from zip into folder
    7. In S3D, File/Import Models
    8. Navigate to folder, select all .stl files
    9. Select all models that need to have same origin
    10. Group (ctrl-G)
    11. Edit -> align selected model origins
  • pete_kpete_k Member Posts: 3 ✭✭
    Hi, I've tried this, and still no luck. Apologies, in the OP I may not have been clear on my workflow -
    What I'm doing is exporting the assembly (after using OS to mate the parts together correctly to get 100% alignment) - i.e. right click on the assembly tab and export - and not the individual parts. So the assembly (and therefor I assumed the parts as well) essentially get a new origin as you are rotating/placing the parts into a new model space.
    When I export the assembly as a single .stl then the assembly origin is correct, however if i export the assembly as individual .stl files (as required for dual extrusion) the origins appear to revert back to the part origins, and not the origin of the assembly.
    The mega clunky workaround I discovered today is to align the parts in the assembly, then simply delete from the assembly one part, export it, then undo the delete, repeat the process for the other part, then you end up with two parts, with the same origin. Horribly clunky - although it works, and it demonstrates that the assembly origin is applied only when there is a single part being exported, and not when more than one part is exported which is a bit weird (at least for my use case).
    Not sure if this is designed-in behaviour or not - there may be a totally valid reason for not wanting this behaviour!
    Thanks for your help though folks - let me know if I'm still not getting it and I'm doing something odd. In my case its usually a P.I.C.N.I.C problem... :)
    Ah, yep, I use a single part studio. I'll try it with an assembly this evening and report back.
    Confirmed that I see the same thing exporting from assembly. Can you assemble the parts in a part studio using the same mate connectors?
  • arnor_eidssonarnor_eidsson Member Posts: 3 EDU
    Hi!
    I also have this problem and really need some fix to it. I cannot do the clunky fix for this as my assemble is to complicated.
    I tested the STL files in Blender and these are the result, one in the left is "One file for all parts" and the right one is "File for each part".
    As you can see its just a mesh and no use for this.
    I know this works in Inventor.
  • christopher_starkechristopher_starke Member Posts: 9 EDU
    Any fix found for this yet? Im also trying to export from an assembly into blender completely assembled.  The assembly has many screws and bolts which I do not want to manually place again in blender.
  • eben_demongeben_demong Member Posts: 1 ✭✭
    A workaround I have been using is to create some small L brackets around the sets of parts that need to be aligned to the common origin.  Select opposite diagonal brackets for each grouping and export each of the two part groups as a single file.  Use the slicer "center" function to align the two groups after importing.
    First part group (2 wedges and pair of brackets)
    Second part group (block and other pair of brackets)
    Export each group from OnShape as a single file.  Import both files to the slicer.  Centering each group will align them to the same origin.  This is working for me with a dual extruder printer (FlashForge Creator Pro Max) using FlashPrint slicer.
  • alnisalnis Member, Developers Posts: 453 EDU
    @christopher_starke @brooks_talley for Blender, use the Collada export. It preserves materials and assembly structure and generally seems to play nice with Blender.
    @eben_demong If you need a common origin and are exporting STLs as a final step, consider making a part studio in context, using transform with the copy-in-place option for all of the parts, then exporting STLs of the copied parts in the in-context studio. That way, all of the parts should have a common origin at the part studio origin. However, this may not work if your slicer is trying to be smart and comes up with its own origins or does something else (I have not tried this method yet--just something I came up with on the fly)
  • billyzelsnackbillyzelsnack Member Posts: 96 PRO
    For 3d printing I typically make an assembly called "plating" In this assembly I use a planar mate between what I want as the bottom of a part and the origin mate connector. I can then freely and quickly move the parts around how I wish. I have 4 printers so moving the parts around freely is important so that I can gather 4 plates of parts such that they complete their prints at approximately the same time. To export I drag select my a of parts and then hide other instance. Then right clicking on the assembly tab I export and save them as a single part (not as a zip). When exporting from the the tab it will export in the assembly coordinate system.
    @billyzelsnack that's a very neat approach! I've heard of people doing something similar in Fusion 360 to lay out parts for CAM, so it's cool to hear that this method also works for 3D printing & Onshape.
