How to add holes to sheet metal flanges
Hi, I have designed a sheet metal box with some flanges generated by the flange tool. I then added a sketch to the flange with some circles and extruded them to create holes. The holes show up in the 3d view but the holes do not show up in the sheet metal view and so are not exported to the dxf file. If I add holes to any other part of the model they do show up in the sheet metal view. Just holes on the flanges are missing. Does any one know what I am doing wrong or if there is a workaround I can use.
    Hi @rick_mcconney ,
    Please hit the "Report a bug" or "Feedback" button from the "?" menu in your part studio.  From there describe the issue you're having and make sure to "share with support".  This will put you in contact with our support team so we can start to investigate and fix your issue.
  • rick_mcconneyrick_mcconney Member Posts: 3
    Not sure why is was not working I quit out of onshape then reentered and deleted the sketch and extrusion and redid it and it now works as expected.
