FeatureScript smooth edges
MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
in FeatureScript, I would like to make my own error message instead of the one generated by opFillet();.
I have written this function to fillet all the edges in a model except the ones that are specified.
https://cad.onshape.com/documents/b7252b2d8824c81fa19efffe/w/62f20e91708c14f2b8e1330f/e/47f23a63404badcd4649270d
I would like it to say that there are no edges that it can fillet if all the edges are smooth
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
    @paul_chastell
    I have redone the feature.
    annotation { "Feature Type Name" : "Fillet Everything" }
    export const filletEverything = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Fillet radius" }
            isLength(definition.filletRadius, BLEND_BOUNDS);
            annotation { "Name" : "Don't Fillet", "Filter" : EntityType.EDGE || EntityType.FACE }
            definition.noFillet is Query;
            //This is the edges that will be filleted
            const edgesToFillet = qSubtraction(
                    qSubtraction(
                        qBodyType(
                            qEverything(
                                EntityType.EDGE
                            BodyType.SOLID
                        qEntityFilter(
                            definition.noFillet,
                            EntityType.EDGE
                    qEdgeAdjacent(
                        qEntityFilter(
                            EntityType.FACE
                        EntityType.EDGE
            //This boolean tells the feature whether the edges are smooth or not
            var smooth is boolean = true;
            var edges = evaluateQuery(
                context, edgesToFillet
            //This for loop detects whether edges are smooth
            for (var edge in edges)
                //This detects whether the selected edge is smooth or not
                if (evEdgeConvexity(
                            context, {
                                "edge" : edge
                            }) != EdgeConvexityType.SMOOTH)
                    smooth = false;
                    break;
            if (!smooth)
                opFillet(
                        context, id + "fillet1",
                            "entities" : edgesToFillet,
                            "radius" : definition.filletRadius
            else
                throw regenError("There are no sharp edges that can be filleted.");
    @paul_chastell
    Thanks!
    @paul_chastell
    Here is what I was doing:
    opFillet(context, id + "fillet1",
                    { "entities" :
                            qSubtraction(
                                qSubtraction(
                                    qBodyType(
                                        qEverything(
                                            EntityType.EDGE
                                        BodyType.SOLID
                                    qEntityFilter(
                                        EntityType.EDGE
                                qEdgeAdjacent(
                                    qEntityFilter(
                                        EntityType.FACE
                                    EntityType.EDGE
    definition.noFillet is the faces and edges not to fillet.
    @paul_chastell
        precondition
                    qSubtraction(
                        qBodyType(
                            qEverything(
                                EntityType.EDGE
                            BodyType.SOLID
                        qEntityFilter(
                            EntityType.EDGE
                    qEdgeAdjacent(
                        qEntityFilter(
                            EntityType.FACE
                        EntityType.EDGE
                            context, {
                                "edge" : edge
                    smooth = false;
                    break;
            if (!smooth)
                opFillet(
            else
