How do you copy sketch entites so that a change in one changes the copy?
Hello,
I've made a lot of copies of a sketch entity (a wire profile) in one of my sketches. How can I copy the profile so that any changes I need to make are reflected in all the copies instead of changing them one at a time? Would using a variable solve this?
thanks for any help
-Metro
thanks for any help
-Metro
That said, If the entities are coincident, you can use the 'project/convert' tool to make copies ACROSS sketches. These would then all be associative.
If the entities were not coincident and they were regularly spaced, then a sketch pattern (again associative), may be what you're looking for.
For better help, most people post a public link so that users can fix your problem.
Good luck!
here is a link
https://cad.onshape.com/documents/1cd2768c01eb0bfcfc7b9a30/w/fce3cebe89a3e337c51b39e7/e/61adafa5269ac0eeea16abb4
they look like upside-down mushrooms.
I'd like to be able to change a dimension on one and have all the copies follow suit if possible.
Here is a document showing that sketch patterns can absolutely do what you're looking for.
Of note is the ability to delete instances (shown) and the pattern still regenerate. That said, there is no need to delete the un-needed instances, simply dont extrude them.
https://cad.onshape.com/documents/9a289276a23d83bc492c357c/w/1cad4ae822c7515d62b5ad05/e/73172fbf24dfcd7dfcc0c99b
I hope this helps
All your profiles are in the same sketch, but in your case they are not evenly spaced. So, a sketch pattern would be problematic. Since everything is dimensioned, you could set each dimension equal to a variable created beforehand. A simpler solution would be to add equal constraints. This would be relatively trivial using a selection set for equal length elements. But the more important question is, what are you trying to accomplish? I imaginge you're going to either extrude or revolve a part from these sketches? If so, a part pattern would be much simpler. Even with your uneven spacing, you could use the Point Pattern featurescript to replicate the parts. And if you need to create a cut, you could just use a boolean after the pattern. And if you're just trying to create the same part over and over, maybe what you need is an assembly. Generally, part studios are best used for creating unique parts, not making the same screw over and over.
