printing sketch ???
jean_didierjean_didier Member Posts: 28 ✭✭
I'll love to be able to print some sketch to use in the shop (aka, the basement...), will not a issue when drawing will be available (right ?? We'll be able to print drawing...) but until them, any suggestion ??
  • emmett_weeksemmett_weeks Onshape Employees Posts: 29 image
    Currently, you can right click on a sketch in the feature list and select 'export as DXF/DWG' from the dropdown. You can print this using the program of your choice.
    I hope that helps.
  • jean_didierjean_didier Member Posts: 28 ✭✭
    sweet !!!! THANKS !!!!!!
