Can the vertices be "Fixed" to each other? A relative constraint?
ron_moreland
                    Member Posts: 90 ✭✭
                    Can vertices be "Fixed" to a plane? or relative to a plane or sketch? I have made some free hand spline curves and I want to "freeze" them, but but frozen relative to a point. I can then move or constrain the point and the curve will follow. It would be nice if the vertices can "unfrozen" so I can adjust the curve, then re-freeze it.
The current "Fix" constraint seems to fix the points to the world. Dimensions to a reference point are cumbersome.
mahir
                            Member, Developers Posts: 1,317 ✭✭✭✭✭
                    Ah, I see what you're trying to do. For that you would need the ability to group entities into blocks. OS can't do that yet. But like you said, transform would work, and I can't think of an easier way to accomplish what you want.5 -
ron_moreland
                            Member Posts: 90 ✭✭
                    The new Mate Connector sketch accomplishes a lot of what I wanted! Thanks!0
When I paste an item into a sketch, there are move handles and I can move the pasted item as a group. A constraint like that.
The "Q" is an imported dxf. Lot's of unconstrained points. I want to constrain the "Q" to be 1" from the edge of the containing rectangle. How do I do that?
How do I fix a point to the sketch? The fix constraint is "fixed" to the world, I think. I think fixing it to the sketch would be helpful.
If you'd like to see functionality that's not currently in the system, please log an improvement request from the Improvement Requests section of this forum. This will allow other users to also promote your idea, and will help prioritize the idea in our system based on number of interested users.
https://forum.onshape.com/discussion/comment/31795
Maybe the next release!
