Extrude up to part
gsk
Member Posts: 5 PRO
I am testing Onshape and ran into a problem with "extrude up to part" function. I was designing a real part which previously was designed using SolidWorks, just to see how Onshape is handling it. Unfortunately, it looks that Onshape extrudes new part/feature to the wrong surface of another part.
Bad part:
The crazy thing is, that if I make different parts just to test this function, it looks to be working just fine.
Good part:
What am I missing here?
Bad part:
Good part:
https://cad.onshape.com/documents/e8be942e9a46b0e914e22d58/w/7810ed5ab78dd26737921f7a/e/9139a0ac8833d965d33d317d
https://cad.onshape.com/documents/3b5ba9957dd84e33d9c95c9e/w/fad45a801938afcc98124e48/e/40031cc7f1b7bf8a3559fa2d
I was able to doi what you want by making a copy of the inside part surface and extruding up to that. A more robust solution would be to extrude to the inside bottom face and use a boolean to remove the drafted/filleted edges.
https://cad.onshape.com/documents/c600443c8be3f6868e43c2db/w/c31ed5035b064c86ea80fdbb/e/fe9145095909994b7f5d40d1
On the other hand, I should probably report problem with extrude up to part function?
