Sharing a Document Version with Export Privileges
Doug_Jones
Member Posts: 28 ✭✭✭
in General
Hello, I am trying to share a version of a document to an outside vendor for quoting, along with download privileges so they can evaluate in their own CAD tool if needed. But I do not want the vendor to have access to the real-time document, only the "quote version". Is this possible? Basically looking for version-specific sharing control. Thanks!
I think your best option here is to:
- derive the version of your part studio into a fresh document, or
- bring the version of your main assembly into a blank assembly of a fresh document as a sub-assembly
(Two options because I'm not sure if you're trying to share a part studio or assembly) Then share that fresh document to the vendor.In this way, the document you share will have a link back to the original document, but also only contain only the geometry from the version you want to share. It will also be easy to update those references to a new version if you want to make changes in the working document and then get a updated quote from the vendor.
This means that you derive/insert your parts/assemblies into a new doc once. Then, if your design progresses and you have a new version that you prefer for your vendor to see, you just update the link in your second document to point to that new version.
In this way, your supplier only sees updates as you’d like them to.
Additionally, you can share that second document to your vendor with comment and export access so that they cannot edit what is there.
Perhaps still not as good as directly sharing a version of the original doc, but I have seen this workflow work with good success!
