Angle lines
graeme_millergraeme_miller Member Posts: 2
How can I draw a line that is on a specific angle ie. 59 degrees from a circle up wards to a fixed horizontal line?
    mahirmahir Member, Developers Posts: 1,292 ✭✭✭✭✭
    This sounds like a basic sketching question. Check out the tutorial linked below. But to answer your question, you will need to add a dimension between your line and another linear reference. That reference can be a construction line attached to your circle.
    https://www.onshape.com/videos/sketching-basics-onshape
