Trying to solid impression this drawing
mark_cunningham
Member Posts: 78 ✭✭
I'm trying to figure out how to impression indent these numbers and dot to dot finalize but i forget how to finalize curvations. also I cant seem to keep an oval in the 6 here. Help is appreciated.https://cad.onshape.com/documents/6b8c218c0fb417b74ebc58ea/w/4543d20f2652d7272b1e5b29/e/dcfd5bbfd54b8475d51f0f5b
Here is the original:https://cad.onshape.com/documents/7494c4e456a7f3f2f67fec23/w/c0837a29816b35600ba6d1cd/e/46de9968e003b1fba4aa9cb2
And what do you mean by keeping an oval in the 6? When I looked at your model, there is an oval in the 6. It's a different part since there is no attachment to the rest of the model, but it's there.
Did you already solve your issues after posting? Looks fine to me.
Is this close to what you wanted: https://cad.onshape.com/documents/1df55bf5c9f815eb887c3611/w/d0e8441b43becc9fe6a5bcde/e/f731380bf1d18a0c53230c81
At the top of her document you should see a 'Make a copy' button. Press that to get a copy of her document, and then you can explore the inputs she used into the two extrude features.
From the current state of your document, what you'll need to do is:
edit: As usual, there are a bunch of ways to do what you want, and Lana did it slightly differently than I described. It may be interesting for you to look at both ways and see which makes more sense to you.
