Build a slide between two rectangles
Kai_himselfKai_himself Member Posts: 45 ✭✭
Hello,
i need your help, i like to build a "slide" between two recatangles, and delet the walls at this slide.
I do not know how do put a sketch on it, i simple can connect the edges of these rectangels....
I made a simple Paint draw to show you how the slide should look like.
Can you help me ? Here is the link to the draw, https://cad.onshape.com/documents/0f68213c9f16e65a6793c709/w/223b3fb90407bc1610e5098b/e/e8937aad3502a9d59d3130e5
Greetz Kai
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,844
    Just use the Loft command and select the solid faces of both blocks. You can then use Shell command to hollow it out.
  • Kai_himselfKai_himself Member Posts: 45 ✭✭
    Thank you for your fast reply NeilCooke, it can be this easy :)
    Greetz Kai
    Looks like you worked it out?
