NextEngine 3D Scanner
So I have a old NextEngine Scanner and cannot for the life of me find the cd-dvd or even my login credentials to the site to download the software to run it. Anyone here have one and be able to help me out?
What software were you going to use to create usable surfaces?
I am looking for something that costs less than Geomagic Raindrop, but also works better than the rubbish SW tools.
Open to all suggestions!
LearnOnshape facebook group
Mark
(we're old friends from SolidWorks days
1. Download ScanStudio CORE 1.7.3
2. Download the Desktop 3D scanner drivers
3. After save is complete, right click in installer and go to Properties
4. Then click on the Compatibility tab and check 'Run this program in compatibility mode for:" and set it to Windows XP SP3 and press OK
5. Now right click on the installer and select 'Run as administrator'
6. Proceed to install and make sure that the 3D Scanner driver box is unchecked (if it is checked, then proceed and just ignore the errors that might pop up)
7. ScanStudio will start with errors, but just close the software after it loads up
8. Copy and replace the wdapi901.dll (link below) to the following directories:
* C:\Program Files(x86)\NextEngine\ScanStudio\Driver
* C:\Program Files(x86)\NextEngine\ScanStudio\DLL
9. Run ScanStudio and plug in scanner
wdapi901.dll: http://nextwiki.s3.amazonaws.com/resources/application/octet-stream/3acd93407807012e451f00254b9c869c-nvwyupzonheur.dll
There are other links for the ScanStudio CORE and scanner drivers but I hesitate sharing them publicly. If you have a login for NextEngine's website you will be able to find those links for ScanStudio and the Drivers easily enough.
Great that you have this solution. I will try out tonight on my Win8.1.
Good to connect with you too Philip. Like the direction you guys are headed. Please say hi to Scott, Lana, Jon, Michael and Joe for me. I would like to introduce Onshape into our client project queue but most of them are using SolidWorks (80%), ProE(10%) or NX(5%). For an engineering consultancy like ours it is a catch-22 in that we can influence many of the startups in SC here - but we default in servicing them with their native system. I think the threshold is close for OS to have enough capability to do consumer and commercial products for our clients but it isn't quite there yet (in my estimation) - still I think there are projects we are currently doing that we could use OS for. Like that you put in configurations. I would like to see you team be more innovative in advanced modeling.
Mark
Good to hear from you. Thank you for your kind comment. I hope that when we are able to turn more attention to Consumer Product functionality you could give us more feedback.
will give this a try on Monday!
But there's good news. Apple has put photogrammetry into the latest OS and iOS versions, and there are a few iPhone apps. I've tried two; PhotoCatch and Polycam. Both have a trivial learning curve, and each gave me great detail and clean, ready to print meshes on the first try. Cloud based arrays at work, for you!!! Better than anything on your desktop. And this was with a $450 iPhone SE 2. Nothing fancy.
Each scan was far better than Nextengine at it's best. With no "place the red,blue and yellow dots", no refining and reducing and cleaning the mesh, no need to go into other sw to clean up the results. You can happily use the bricked device as a door stop.
There's also something from Epic for Android, but I haven't used it.
Good luck!!!
It's dead unless you can set up an old machine that runs Win7 and Flash. And keep it off the network for security reasons. Don't bother, though.
There's good news. Apple has put photogrammetry into the latest OS and iOS versions, and there are a few iPhone apps. I've tried two; PhotoCatch and Polycam. Both have a trivial learning curve, and each gave me great detail and clean, ready to print meshes on the first try. Cloud based arrays at work, for you!!! Better than anything on your desktop. And this was with a $450 iPhone SE 2. Nothing fancy.
Good luck!!!
