Sketch references on and transformed part
Does anyone have ant ideas regards why I cant make sketch references on a part that has been moved by a transform. The only way I see how to do this is to make a copy of the part during the transform.
in "Sketch 2" if you right click on the box edge line there is no "use" on the menu to reference the box edge line, if you change "transform 1" to "copy part" then you there is a "Use" on the menu
Please confirm that you are using a supported browser (chrome, firefox, safari)?
It is true that you do not get the 'use' on your RMB menu.
The good news is that the kb shortcut DOES WORK - Hopefully you are now unblocked!!!!!
I will write this up as a bug!
The 'use' option in the context menu is actually a shortcut for the 'use' tool in your sketch toolbar:
https://cad.onshape.com/help/Content/sketch-tools-use.htm
You can click on that tool or even use the 'u' shortcut to use that edge.
The visibility of the 'use' option in the context menu is controlled by a number of different factors, if you would like us to look into why it isn't showing up in your case, please press "Report a bug" or "Feedback" under the "?" menu near the top right corner of your Part Studio.
