Sweep direction
gal_raz
Member, Mentor Posts: 39 ✭✭
partpath and it follows it. I want to understand what you are after?The UI for sweep really depends on the path either beginning or ending on the face being swept, thus eliminating the need for a direction, as it becomes fixed at that point.
If a path is intended to be started in the middle or not at the end, an end control would solve that or redefining the path to have the desired start/end and length. Does that make sense?
