how to make a sweep starting from not the origin?
wouter_visser
Member Posts: 14 ✭✭
I'm modelling a vacuum cleaner and having trouble with the 'trunk' part. It's easy to draw a circle on the body of the vacuum cleaner, but I can't figure out how to make a path in a plane perpendicular to that circle, starting at the middle of the circle. Is there a feature for projecting geometry somewhere?
There are many ways to make the plane you are interested in, but I think this is probably the simplest:
https://cad.onshape.com/help/Content/cplane.htm
https://cad.onshape.com/help/Content/sketch-tools-use.htm
