Extrude with form oblique on the sites only
Kai_himself
Member Posts: 43 ✭✭
Hello,
i need to extrude a output. On my Projekt https://cad.onshape.com/documents/59c86ee900a052ff6418617d/w/fc3b877b638f2da9fa030087/e/935f191b14ecb711b3d0964c. I try to visualize it with paint. The sides should be diagonally, but the top and the bottom straight.
With the form oblique in the extrude tool, i got all sides diagonally.
How i do a diagonally extrude ?
Thank you Kai
Thank you Kai
i extrude straight the sketch6 (big manhole), but where do i found the draft feature ?
sketch10 is the small manhole.
You actually need two drafts to achieve this effect, here is an example:
https://cad.onshape.com/documents/8f3caf46732d7af00e32decc/w/e14398bd5bc3e948bd4ed6a0/e/615241abfe6906d16838d80b
https://cad.onshape.com/help/Content/draft.htm
@elif came up with a better workflow:
https://cad.onshape.com/documents/8f3caf46732d7af00e32decc/w/e14398bd5bc3e948bd4ed6a0/e/7ccc1028bc40251256ebe81c
- Extrude the rectangle as a solid straight block
- Draft the sides in
- Use 'shell' to remove the top and bottom faces
https://cad.onshape.com/help/Content/shell.htmThank you for your Help, i did it too, but i a very much complicated way.
At step 2. what i have to select to draft the sides in ? Nothing happens to me.
Greetz Kai
sorry my fault, i did it, very good way Thank you yery much !
In the screenshot you've provided, you appear to be editing a 'Variable' feature: https://cad.onshape.com/help/Content/variable.htm
In my example, I made a variable called 'draftAngle', which I then used as input to the 'Draft' feature:
It appears that you've already copied my example document. If you go into the copied part studios, you can double click on any feature to edit them and see the inputs and effects of the feature. This will be the easiest way to see how I've accomplished the desired geometry.
