Extrude to another slightly differently shaped sketch
I'm trying to extrude from one sketch so another that has a slightly different shape. I tried extruding to another face (stern plane) and selecting the plane of the second face but it preserves the shape of the original shape (bow). I assume this is a relatively easy operation but I haven't been able to find the solution by watching videos or looking through the discussion board.
The two shapes I'm trying to join are here. Screenshot below:
This is my failed attempt at the extrusion, it is an extension of the "bow" sketch. I wasn't able to find a way to easily associate the matching points between the two shapes.
owen_sparks Member, Developers Posts: 2,660 PRO
Have a read of the help section for the loft function and you'll be all good.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
