Reordering Mate Features
jon_woellhafjon_woellhaf Member Posts: 92 ✭✭✭
I can drag and drop to reorder -- or rearrange -- Instances. Is there a way to do the same with Mate Features?
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    edited February 2018
    I don't believe so, other than deleting your mates and recreating them in the desired order. I can't say for sure, but I suspect it's more of an aesthetic issue, and that the mates don't necessarily solve in the same order that they are listed. It's likely a multi-threaded server task with all the mates solving simultaneously. @ilya_baran, amiright?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    @mahir You're correct -- the order of mates should not matter, as they are solved simultaneously.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
    @mahir @ilya_baran I think what the OP is asking is there the ability to move and group mates to make it easier to understand structure. For example, I like to have my main pivot mates at the top of the list and at the moment I can only do this by creation order.
  • jon_woellhafjon_woellhaf Member Posts: 92 ✭✭✭
    Bruce, yes, that's correct. Thanks for clarifying.
    Please submit an Improvement request in the 'Improvement Requests' section of this forum to put this on our radar and help us prioritize the work!
