Removing a section of a extruded tab
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
edited February 2018 in General
https://cad.onshape.com/documents/5248b23741bbb4ad0133e9ca/w/4db2a12bd146cc9851d6291c/e/0ff91e50b1f6d3429c59ba46
If you look at these tabs you might see that from the edge of the radius that they are cut back to a degree, but not all the way up the tab so as to leave a beveled top. This is so it can snap into place to there perspective slots. I'm trying to figure out how to cut a section of the tabs back from the edge of the radius.
    1) make a revolve remove to cut the relief  OR
    2) start over with a revolved shape including the relief & bevel.  Then do an extrude remove to take out material between tabs
    www.accuratepattern.com
  • mark_cunninghammark_cunningham Member Posts: 78 ✭✭
    Thanks for the reply Bruce. If I knew the procedure for resolve remove i would rather do that! Once my parts are shown as a extruded solid i don't how to change anything.
    The Learning Center is a great place to find how to use Onshape.  It is under the question mark menu.
