How to give mating in a ball bearing.
chand_basha
Member Posts: 63 EDU
Hi,
I want to create a ball bearing, I have created all the individual parts. But I am not getting how and what mating I have to give between the parts. Please some one help me,
here is the link:
https://cad.onshape.com/documents/c444dca01f4985c4b583f478/w/22b9cd76a1778ba64cbafe81/e/16ef3ff905844bf6ccf388f9
here is the link:
john_mcclary
Member, Developers Posts: 4,001 PRO
You shouldn't really waste time mating a bearing.
But if you really want to:
In part studio create a mate connector to center of inside or outside race, then set it's parent to one of the ball bearings.
Fix: outside race
Revolute: inside race + outside race
Group: All Ball bearings
Revolute: Ball bearing mate connector + inside race
Now if you like realism with the above setup:
Use gear relations between ball bearing mates
But seriously, just use 1 group mate on everything. Or do a boolean union in a part studio for bearings
5 -
john_mcclary
Here check out this example
https://cad.onshape.com/documents/17ed8cc618a401e2c2675331/w/e891548b7dbb0c5c203b7cef/e/ced12697feb16c22c12158ea
5
Fix: outside race
