How do i extrude a plane and drawing on a angle?
tom_scott
Member Posts: 4 ✭
I am drafting a chair. I have mirrored the back leg - but the back slats are level on a leg the curves away - when i try to extrude them they dont extrude level. Thanks in advance.
michael_mcclain
Member Posts: 198 PRO
Judging from the pictures it looks like you used the inner face of the upright members as the sketch plane. That face does not look vertical so your extrudes are skewed.
You can try to extrude from the right plane and sketch the cross section. Run the part long and then use "split" to trim the excess ends and use "delete part" to get rid of them. You can also create a plane normal to the view in the picture and sketch the full profile, but this may be harder to position the piece correctly and if you reference the inner faces in your sketch, the sketch could be fragile. I recommend the first suggestion.5
