planetary reduction gear
hi,
i have designed this planetary gearing mechanism, in this the ring is fixed. the in put is sun gear and the out put is planet carrier. when i am trying to give mating the animation is looking intersected. so help me how to give mating b/w fixed ring gear and revolving planet gear
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
Here's a link to a functional example.
https://cad.onshape.com/documents/afef36773400edbb60adf7ef/w/293214089ddddea9f823d1af/e/165a47a6e04f9af368a00b09
6 -
Here's a fixed version of your assembly. I just had to adjust some of the mate connector alignments.
https://cad.onshape.com/documents/cd8786a0636b6a309c217ba3/w/8ed6d9586b8e414e2c0376df/e/4b47896360c019f96f350cbe
5
https://cad.onshape.com/documents/1fa61d7170a83151a52a0a08/w/8ab15e2e2d07991e09eed0de/e/60ec06eb1e6edffd6107628f
Sun gear to carrier
1X planet gear to carrier (or sun gear)
2X planet gear to planet gear (just a 1:1 ratio to the planet gear that is driven by the sun/carrier)
This should explain everything
https://cad.onshape.com/documents/d99fefa5f3f11705853847ec/w/1da1f2ac6c849c9170fa6cec/e/4e9352615b50d2e620d480c5
https://cad.onshape.com/documents/933b7b93dcd1aa2bae75a3b4/w/c7260aa152d18de55edcd616/e/c72cb41f04f1a34129260403
