Kiri : Moto not working in Safari.
I am trying to use the Kiri: Moto CAM app in Safari. And everything loads but the rendering space. Below is a picture of the issue with the Java debugger for Safari turned on. It seems to indicate a number of errors.
I've checked that I have the most up to date version of Java and that permission for Java on both the Onshape app store and website are turned on.
It works in chrome, but I work in Safari. I of course can switch when doing cam processes, but that is really not an ideal work-flow.
Anybody else experiencing this issue?
awk Member, Onshape Employees, Developers Posts: 78
This is a known (https://bugs.webkit.org/show_bug.cgi?id=175783) issue in Safari 10 & Safari 11 (https://bugs.webkit.org/show_bug.cgi?id=171054). According to those issue reports it has been fixed, but the fixed version is not yet available as a public download.
In the meantime can you try Chrome on Mac OS X ? I don't believe this problem exists on that browser.
(Also - for completeness, you're referring to and seeing the Javascript debugger not Java. They're quite different and neither Onshape, the App Store nor Kiri:Moto use Java, they're all implemented using Javascript - updating your Java version won't have an impact on this error).Director of API, Appstore, and App Partner Technical Support5 -
andrew_jorgensen202 Member Posts: 12 ✭✭
I found another work around for the time being. You can download Safari Technology Preview from the link below, and it fixes the webGL render issue. Of course what other surprises you might run into with Technology Preview addition is another problem...
But I'll try it for now and see how it goes.
https://developer.apple.com/safari/download/
