Flange to form a tab = i.e. Flange Bend Angle of 0deg.
phil_joycephil_joyce Member Posts: 13 PRO
I am trying to create flat tabs and thought the Flange tool would be ideal, but it does not allow 0 degrees bend angle. Is that because zero would upset background geometrical calculations? Align to Geometry looked a good bet, but I can not get it to work. Any advice out there?
The subject:
https://cad.onshape.com/documents/c717b32738899ba2d2fb177b/w/41ec7202d9e732db15c76fa8/e/ea7818291a9058976bb276ef
  • phil_joycephil_joyce Member Posts: 13 PRO
    How very short sighted of me. Thank you very much.
    I am still interested to know if it is a 'Divide by 0' problem that prevents a Flange Bend Angle being set to zero. It is a valid reason. but hey, my problem is solved, thanks again.
    @phil_joyce
    You could also use the move face command. :smile:
