New Sizes of Standard Content
@NeilCooke @Lougallo is there a way to add new sizes (lengths) to items in the standard content?I need a M10 socket head bolt about 125mm long. The M10's stop at 90mm
Right now our standard content only supports content that is defined per ANSI and ISO standards. This component is compliant with ISO 4762:2004.
This is the current, not withdrawn standard. The standard says the maximum nominal length is 100mm, which is what we have.
To use a non-standard bolt, I would suggest go to a content supplier and download their component of the size you are looking for.
