Onshape sign in problem
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Been trying to sign in to Onshape using Chrome on windows 10. Advised to do this because of problem with balloon callouts in safari. However Onshape will not accept my password which I know is correct. The message I get is (email or password is incorrect) this I know is not the case.
Can anyone advise how to overcome this
Brian.
    Our support team is on it! You should be hearing from them soon.
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Many thanks, contacted by support and problem solved. just needed to reset password .
     Brian.
