Counterbore slot
richard_lord
Member Posts: 2 ✭
Is there a direct function to create a counterbore slot to retain a hex headed set bolt?ff
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
Nope. But you can try to leverage the sizing smarts of the Hole feature by creating a couple normal counterbores of the correct size and cutting out the space in between. You can also write a featurescript that automates the process by building off the Hole feature and combining it with an extrude or sweep that follows a sketched slot path.5
