How can I translate a sketch?
ts_2
Member Posts: 22 ✭
I just can't find a simple way to move a sketch I already made, and align it, or move it into position, and then extrude it. I feel like it should be stupid simple to do, but its not there, or its not obvious. help. Constraints feel like they dont help at all. I've already made my rectangle sketch and have to Center it above something. Also a tutorial on how to do this might help. I can't find basic theories on moving and interacting with sketches. Moving them around, aligning things etc..
You can use the show constraints tick box too see all constraints on the sketcher dialogue.
You then have to find the constraint or dimension locking your segment of sketch down and delete so it's free to move then add your new constraint as required.
Construction Lines can help too. Magic thing in Onshape is you don't have switch to a construct lines to get your extrudes to work just leave it as a normal line.
No way to copy elements of sketches in the sketcher in Onshape yet. My ticket for this is 1646. add yours with the ? (feedback) top right.
I think you can use a face of a part as a plane to draw the next part on so it is in the correct relationship to the first part.
Dave
Ariel, WA
1) edit the location of the plane you are sketching on (provided it is not a construction plane, ie Front etc)
2) edit the sketch and choose a different sketch plane, which will relocate the existing sketch to that plane (Note that this can be used to reposition in z only, but can also turn the sketch to a new aspect if the planes are not parallel)
Hello! Here is what I did after I sketched two splines to form an open S-shape (highlighted). I liked the shape but found that it didn't intersect the part correctly and needed to be rotated and moved a bit. (There are no dimensions on the splines, just 'free handed'). So what I did was create an 'Extrude - New' which created a new part with the S-shape. Now I can transform that part to where I want the S-shape! I wanted to cut the S-shape into the existing part, so I could do a 'Boolean-Subtract' or I could create a new sketch and do a 'Use (Project/Convert)' and pick the face of the transformed part! See the sketch entities "hanging in space". This recreates the S-shape on the new sketch plane! (FYI, the green part is a sweep and not a flat surface)
