Strange behavior of FOR loop for real iterator.
edited April 2017 in FeatureScript
in this simple test feature i reproduced the sutuatuin when number of iterations
of my loop is +2 bigger then one would expect for test values bigger then 127 degrees
https://cad.onshape.com/documents/c0429467b6e5c445825d5e38/w/4ac0768c5fbd908e4dd309f6/e/d53b7f0578bcaaa9835d8461
FeatureScript 559;<br>import(path : "onshape/std/geometry.fs", version : "559.0");<br><br>annotation { "Feature Type Name" : "My Feature" }<br>export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)<br>    precondition<br>    {<br>        annotation { "Name" : "My Angle" }<br>        isAngle(definition.myAngle, ANGLE_360_BOUNDS);<br><br>    }<br>    {<br>        var list = [];<br>        for (var phi = 0 * degree; phi < definition.myAngle; phi += 1 * degree)<br>        {<br>            list = append(list, phi);<br>        }<br><br>        list = append(list, list[0]);<br>        debug(context, size(list));<br>    });
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    I didn't check, but I expect you're running into floating point tolerance issues -- keep in mind that addition is not an exact operation and neither is multiplication by degree (since our internal units are radians).  To fix this, I suggest you either add or subtract TOLERANCE.zeroAngle * radian to definition.myAngle (depending on whether you want inclusion or exclusion).
    thanks @ilya_baran, i suspected it was because real iterator, but hardly belived that it can add two more iterations after only 127
    It's only adding one more iteration: the result of adding 1 degree 127 times is very slightly less than 127 * degree.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,056 ✭✭✭✭✭
    @konstantin_shiriazdanov
    Would it fix it if you divided by degree before doing the for loop?
    @mbartlett21 possibly if i had unitless integer iterator and multiplied it by degree inside the loop it would work without taking tolerances into account. don't think dividing by real number would help for it
  • john_f_carrjohn_f_carr Onshape Employees Posts: 74
    The FeatureScript range() function may help you.  It divides a range into equal steps and ensures the last value is equal to the upper limit.
