Turning on part planes in an assemly
Perhaps I'm going about this the wrong way, but I'd like to use an existing plane in a part to create a section view within an assembly. Ideally I'd like to turn on a parts plane in assemly studio, so that I can select it to use as a viewing section. Does that make sense? I know it's often not a problem and you can drag and rotate from planar faces. But sometimes a lot of work has gone into creating a plane in an organic shape and it would be great to just pick that plane to section the assembly.
Thanks in advance.
Thanks in advance.
1
Jason_S Moderator, Onshape Employees, Developers Posts: 223
You cannot import planes into assemblies (yet), but If you create a Surface that represents the Plane you would like to take a Section view of, you can import that Surface into the assembly. Then you are free to make the Section plane on that newly imported Surface.
Let me know if you have any questions!
JasonSupport & QA6
Jason
Frustrated.
For example, here is what I see when I only have parts (no filters):
Here is what I see if I have both solids and surfaces (the filters appear):
And if I go to all surfaces then the filter again disappears.
And here's an assembly with a surface inserted:
TVP, Onshape R&D
The easiest way to make a surface representing any plane in your part studio is to make a rectangular sketch on the plane in question and then do an "Offset surface" of that sketch rectangle with an Offset value of 0.
https://cad.onshape.com/help/Content/offset_surface.htm
Mate Connectors come in from the part studios which make snapping parts together really easy. https://learn.onshape.com/learn/article/advanced-mating-techniques
Also inserting sketches from the part studio is really a useful technique for layout modeling as Mahir mentions . https://www.youtube.com/watch?v=Rvu9763-2I4
